Deforming object iteraction with FLIP
Mozzarino
Is there anyway other than changing the "velocity scale" under flipsolver->volume->collisions to change the influence scale of an animated collision object with the FLIP fluids?
I'd like to try and have a by-object control...
I tried changing the velocity of the SOP that I am using as deforming object but with no effect...
17 hours ago, Navneet Arora said:
You can try incorporating velocities from the object itself by sourcing some and adding to flip velocity.
I also tried that, but the flip tank fills the holes left by the collisions with the source volume... its weird, its like there is only collisions below the water surface.
