Houdini + ZBrush
Alexey Vanzhula
Alexey,
Have you had the opportunity to target this utility on a macOS environment yet?
My attempt to use OTL version Z 1.2 + Houdini 17.0.416 + ZBrush 2018.1 + macOS 10.14.2 has not been successful, usually causing either application to crash.  It might just be a matter of specifying a properly-formatted application path as the exec_path value, but none of the variations I've tried seem to work properly.
Note that GUI-based executables can behave a bit differently on macOS than on Linux.  For example, here are some ways to launch an application from the command line:
/usr/bin/open -b com.apple.textedit
/usr/bin/open -a /Applications/TextEdit.app
/usr/bin/open -n ./TextEdit.app --args -AppCommandLineArg
/Applications/TextEdit.app/Contents/MacOS/TextEdit&
3 hours ago, Cyzor said:
Alexey,
Hi. Thanks for the info. I'll contact you later
