tricking visibility without multiple render passes
Hello!
I am stuck trying to solve a problem. I have these aperture like petals that I want to disappear in a physically impossible way [see gif].
https://gfycat.com/skinnysneakyjaeger
You can see in the photo I accomplished this using boolean. However, I cannot keep using boolean because it is affecting my material. I have a rest position on the "petals" geometry to keep the texture in place, but when the "petals" geometry starts getting deleted by the boolean sop, it starts making the material freak out slightly. My second idea was to use the same geometry I used for the boolean [third photo] but instead make it a have a matte material instead of boolean. This works, but it starts cutting out other geometry in the scene. Is there a way to make it so the object with a matte material only affects some of my geometry? Is there a better way to solve this problem? I want to avoid rendering out the petals geometry in separate passes. I also need to trick the visibility for some gears too, so I don't want 50 render passes.
Thanks
Edited by ejr32123
thanks for the answers. what anim said about opacity in the shader sounds good but I'll have to figure out how to do that. Not sure if the first method would work. Seems like it would make the texture stretch.
Edited by ejr32123
here is an example with multiple holes of different position, rotation scale
all petals are packed and reused among holes so it should be efficient even with thousands of them, the masking is happening only in the shader with the help of some attributes from SOPs to get the correct circular projection
ts_mask_by_opacity_.hip
  • Like 2
  • Thanks 1
