art3mis Posted January 6, 2019 Share Posted January 6, 2019 (edited) Hi Any Vellum experts able to tell me if its possible or even a 'best practice' 2 combine 2 or more Vellum Drape SOPS in the same network? I have a character with under (Layer 0) and over (Layer 1) clothing meshes. They seem to each require different draping settings in order to drape correctly. Hence my choice to have separate Vellum Drape operations in my network. Afterwards I merge the geo and constraint outputs and feed into a single Vellum Solver for animation. My separates drapes are correct and I've frozen and cached each. But on final simulation (in the Vellum Solver) my geometry 'explodes' Attached is a screen grab of my network and my Vellum Solver settings Edited January 6, 2019 by art3mis Quote Link to comment Share on other sites More sharing options...
anim Posted January 6, 2019 Share Posted January 6, 2019 that shouldn't be an issue as long as your 2 layers are not penetrating there are some attribute conflicts however on your merge nodes so double check that everything has expected values coming into vellum solver it may be a good idea to remove all simulation attributes that drape may have created and keep only important constraint and vellum material attributes that vellum constraint nodes created your screenshot is not informative at all, just shows what you already described, so hard to judge, simple scene would be better Quote Link to comment Share on other sites More sharing options...
art3mis Posted January 7, 2019 Author Share Posted January 7, 2019 Thanks!. Was deconstructing the THUG example by Sara Rascon and wondering if a better approach is to avoid use of merge and use Cloth Constraint with Pin Animation after you've finished a drape So you would have Cloth Constraint-Layer0 Cloth Constraint-Layer0 VellumDrape1-Layer0 ClothConstraint_Pin Animation for above Cloth Constraint-Layer1 Cloth Constraint-Layer1 VellumDrape2-Layer1 VellumSolver (for animation) Dunno, still learning! Quote Link to comment Share on other sites More sharing options...
