Move to origin and restore original position
kiryha
I think its better to use centroid rather than CEX. If you use centroid you will actually see values and not just "0".
centroid(0,D_X)
then you can duplicate the transform node and use the invert transformation button.
http://www.sidefx.com/docs/houdini/expressions/centroid.html
Edited by ejr32123
Here is move an object to origin with VEX:
// Get center of the oject bounding box (centroid)
vector min = {0, 0, 0};
vector max = {0, 0, 0};
getpointbbox(0, min, max);
vector centroid = (max + min)/2.0;
// Build and apply transformation matrix
vector translate = centroid;
vector rotate = {0,0,0};
vector scale = {1,1,1};
matrix xform = invert(maketransform(0, 0, translate, rotate, scale));
@P *= xform;
// Store transformation matrix in attribute
4@xform_matrix = xform;
Return to original position:
@P *= invert(4@xform_matrix);
move_to_origin_001.hipnc
  • Like 5
  • Thanks 1
  • 7 months later...
@P *= xform;
Hi, thanks for this and it's wonderful and works for particles.
However, it doesn't seem to centroid the rotation as well?
