Unified Noise - Static
reeson
Ah ok, I could get rid of them by increasing the source min/max to 0.1 and 0.11 . Then the grey portions turn into black pools. If you don't want those you may want to go with a more SOP solution than VOP using voronoi and some attribute noise on P and then ray back onto original geo. Or you can use edgeFracture or findShortestPath to create those lines.
Edited by kleer001
