Dogman27 Posted January 29, 2019 Share Posted January 29, 2019 (edited) Sorry, kind of new to Houdini here & surprised I can't figure this out: How do you stop smoke from being emitted within a dopnet? I have a scene where the smoke from an object ( a cube wired into an object merge wired into a fluid source node that creates smoke density) and then I use a suction target to make the smoke form into text when it rises. The thing is I only want the source to be emitting smoke for about 24 frames, and then I just want to watch the emitted smoke form into words. Does anyone know how I can do this? Thanks! Edited January 29, 2019 by Dogman27 added detail Quote Link to comment Share on other sites More sharing options...
ryew Posted January 30, 2019 Share Posted January 30, 2019 Quickest way is just to animate the Activation attribute on your Source Volume node to 0 on the 25th frame or set $FF < 25 in that field 1 Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted January 30, 2019 Share Posted January 30, 2019 another way is to animate your Volume source node, you can animate the scale from 1 to 0 in your density field 1 Quote Link to comment Share on other sites More sharing options...
yesyes Posted January 31, 2019 Share Posted January 31, 2019 another method is to................................... why do you need so many methods? just use the ones posted Quote Link to comment Share on other sites More sharing options...
