Daniel16_16 Posted February 6, 2019 Share Posted February 6, 2019 (edited) Hey, all I have a basic voronoi fracture sim, so then I have add derbis and after that billowy smoke... all works fine I can see the smoke from the debris in the viewport, but I CAN'T see the smoke in my render view? what I make wrong??? Edited February 7, 2019 by Daniel16_16 Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted February 8, 2019 Share Posted February 8, 2019 There's a vast number of things that could go wrong from your description. Post a hip file and I'll check it out. Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted February 9, 2019 Author Share Posted February 9, 2019 Here is the file Problem render smoke as debris.hipnc Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted February 9, 2019 Author Share Posted February 9, 2019 On 2/8/2019 at 10:51 PM, Midasssilver said: There's a vast number of things that could go wrong from your description. Post a hip file and I'll check it out. Expand here is the file... Problem render smoke as debris.hipnc Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted February 11, 2019 Share Posted February 11, 2019 Here, I fixed your file. Lots of things that need to be corrected here. First, you weren't seeing your sim, you were seeing the source of your sim. Second, the bounding box of your sim was way too small, and not even in the right place, so you wouldn't get any smoke even if you tried to sim it. I uploaded the file with the changes. Problem_render_smoke_as_debris.hipnc Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted February 11, 2019 Author Share Posted February 11, 2019 thx, but I have solve it myself Quote Link to comment Share on other sites More sharing options...
