How could I expand border edges..?
Masoud
29 minutes ago, kleer001 said:
Group the edge then Peak SOP and transform by normals?
that would work for the straight bits, but for the corners you would have to increase the magnitude by which you move them to maintain the angles.
from the top of my head.. I think it was dividing the offset by either the cosine of the angle, or the cosine of half the angle.
So an offset at the corner, at 45 degrees would be 1/cos(45deg) which is 1/0.70710678118 = 1.41421356237 if my memory serves me right.
Which makes sense, as that is the square root of 2, and pythagoras and stuff :P
Edited by acey195
You could also loop over the outer points with a detail wrangle:
int pts_grp[] = expandpointgroup(0, 'outer');
int total = len(pts_grp);
for(int i = 0; i < total; i++){
    int pt_prev = pts_grp[ (i - 1) % total ];
    int pt_curr = pts_grp[ i ];
    int pt_next = pts_grp[ (i + 1) % total ];
    vector next = normalize( point(0, 'P', pt_next) - point(0, 'P', pt_curr) );
    vector prev = normalize( point(0, 'P', pt_curr) - point(0, 'P', pt_prev) );
    vector avg  = normalize(next + prev);
    vector up = {0, 1, 0};
    vector in   = cross(avg, up);
    float dist  = dot(next, avg);
    vector dir  = in / dist;
    vector offset = dir * -chf('extrude');
    setpointattrib(0, 'P', pt_curr, offset, 'add');
Forked from: https://forums.odforce.net/topic/41356-polyextrude-in-vex/
expand_3.hiplc
Yeah Konstatin's version is basically a worked out version of my ramblings.
Forgot to note that the dot product of 2 vectors is equal to the cosine of the angle between those vectors, making the code kind of convenient :)
@konstantin magnus Just realised you got this technique from the genius himself too :D (in the other thread)
