Whatsinaname Posted February 27, 2019 Share Posted February 27, 2019 Did anybody have any success with vellum cloth on fast moving objects? I'm doing cloth on a character, who is free falling. It's done by an animator and speed-wise, it might be slightly overdone, but there's no way to change that. Simulating cloth on the character using Maya nCloth, I got proper results, but it was still nCloth and therefore slow and painful. I recreated the setup using vellum, but no matter how much I increase substeps, everything is exploding right away. It is working fine with a localised version, but I was wondering if there is a special trick or anything worth considering when using Vellum with fast moving objects? (Unfortunately, I cannot post the scene file) Quote Link to comment Share on other sites More sharing options...
sebkaine Posted February 27, 2019 Share Posted February 27, 2019 (edited) would it be possible to neutralize the transform of your char , in order to stick it at the center of the world , then work on a static char by using forces for wind, you could also take a certain percentage of the animation like 10% or 20%, to inject this in your sims for better result. then you reset to the correct transform with the baked anim of your cloth, and see if the tricks works ? Edited February 27, 2019 by sebkaine 1 Quote Link to comment Share on other sites More sharing options...
Whatsinaname Posted February 27, 2019 Author Share Posted February 27, 2019 Yes, that works nice and fine. I was only wondering if there is a way to make it work without localising as it does so in nCloth. Quote Link to comment Share on other sites More sharing options...
anim Posted February 27, 2019 Share Posted February 27, 2019 3 hours ago, Whatsinaname said: (Unfortunately, I cannot post the scene file) any broken example file will do by not posting anything you are expecting people to build their own example to see whether they will even run into your issue and then try to fix that, essentially your chances for getting a solution without broken setup are much lower 2 Quote Link to comment Share on other sites More sharing options...
gregjenings Posted July 22, 2021 Share Posted July 22, 2021 Could anyone explain step by step methods, Node graphs etc, How I can perform local simulation and bring my fast-moving character and its environment to the local position in Houdini? I'll try to upload a crude example file if anyone required it. Quote Link to comment Share on other sites More sharing options...
