Multiple Constraints on One Object
PortalPyro98
I was wondering if anyone has had experience having multiple constraints on the same object and breaking them apart separately. the effect I'm aiming for is to have a some large rocks be ripped of a section of rubble and while in the air start to break apart into smaller pieces. I've tried setting up my constraints based on the groups created from the Voronoi fracture and sub fracture nodes, however this causes problem when trying to disable the constraints in different areas.
Any ideas?
ConstraintsHelp.hipnc
NewRubble.abc
1 hour ago, kiryha said:
I had the same issue:
I can post a hip file with my destruction if it is what you are looking for.
Thanks, If that would be possible it would be a great help in being able to understand the process more fully.
