Curve attract Particles problem
Daniel16_16
hey all,
I have a curve, which is attract particles. Everything is fine, BUT the outer particles only fall down without a curveforce...
SO I like to make a tornado with particles. but the outer particles fall down... how can I delete them or make attract to the curve??
and you can see in the screenshot that the inner particles a attract to the curve but the outer are fallin' down... :(
tornado problem.hipnc
  • 1 month later...
Hello Daniel,
in the popcurve force there is a parameter called 'max influence radius. by increasing that one, the radius of your curve will be bigger and catch all the particles outside as well.
I woudnt reccoment deleting them otherwise if they go from the curve to outside, you'll see them disappering and popping out.
Good luck!
