jackassol Posted March 29, 2019 Share Posted March 29, 2019 Hello guys - may its really simple, but how can I animate a soft/dynamic movement transition to the starting point of my vellum animation? should go dynamically - not with blendshapes! Basically like the targetstiffness/ targetposition we have in gains. Is that possible with vellum? I uploaded a file... Thanks back.hiplc Quote Link to comment Share on other sites More sharing options...
Atom Posted March 29, 2019 Share Posted March 29, 2019 You can always keyframe gravity, kick out a geo sequence and use ReTime to play it back as you see fit. ap_keyframed_gravity_back.hiplc Quote Link to comment Share on other sites More sharing options...
jackassol Posted March 29, 2019 Author Share Posted March 29, 2019 (edited) Thanks - Atom. I dont wanted to touch/animate any forces, because my scene is way more complex. It should move/morph to an specific target/rest position - or even better - an animated restposition. Is that possible with vellum? Its the same like the "Cloth-target" in the older houdini versions. Like here: Edited March 29, 2019 by jackassol Quote Link to comment Share on other sites More sharing options...
anim Posted March 29, 2019 Share Posted March 29, 2019 Use Pin To Target constraints and set them to Soft with desired stiffness Quote Link to comment Share on other sites More sharing options...
jackassol Posted March 29, 2019 Author Share Posted March 29, 2019 perfect. thanks Quote Link to comment Share on other sites More sharing options...
jackassol Posted March 29, 2019 Author Share Posted March 29, 2019 ok - one more question: how can i use a separate goal/geo which is animated? How can I change the link to to a "self-made" goal? Quote Link to comment Share on other sites More sharing options...
anim Posted March 30, 2019 Share Posted March 30, 2019 17 hours ago, jackassol said: how can i use a separate goal/geo which is animated? How can I change the link to to a "self-made" goal? - if you are using Vellum Solver SOP then Advanced/Target, change to SOP Path - if Vellum Solver in DOPs then there is Target Path on Vellum Source DOP Quote Link to comment Share on other sites More sharing options...
jackassol Posted March 30, 2019 Author Share Posted March 30, 2019 amazing tomas! Quote Link to comment Share on other sites More sharing options...
