[SOLVED]Lossing Rest field after converting VDB
Marcocheng
Hello folks!
I'm currently playing with pyro with volume displacement (Arnold), i have to convert my volume into vdb so that it can rendered with Arnold, i plug the convert VDB after my volume cache, rest and rest2 field turns zero. I wonder what causing that. I'm working with Houdini 16.5. Convert VDB sop remains default value and parameter.
Before convertVDB:
After convertVDB
Hope for an anwser! Thanks!
Also if there is a way to combine each scaler field into single vector field? thanks again
Edited by Marcocheng
23 minutes ago, anim said:
Your rest fields are probably empty, therefore VDB will contain 0 voxels as it ignored empty ones since it's sparse
You can use VDB Vector Merge to combine float to vector fields
Thank you Tomas. Prehaps starting frame not equal 1 causing the empty rest field result?
PS:emm i found offset the rest field works fine, thanks again!
  • 10 months later...
On 6/4/2019 at 4:19 PM, Marcocheng said:
Hello folks!
Before convertVDB:
After convertVDB
Could you please tell me how to use rest in Arnold?
