Masoud Posted June 7, 2019 Share Posted June 7, 2019 Hi; Is it possible to transfer colors from geometry's material to points? I found this thread: https://www.sidefx.com/forum/topic/12562/ But I want to get texture from any input geometry, procedurally. Thanks. Quote Link to comment Share on other sites More sharing options...
ikoon Posted June 7, 2019 Share Posted June 7, 2019 Hi Masoud, isn’t Attribute from Map SOP what you need? https://www.sidefx.com/docs/houdini/nodes/sop/attribfrommap.html Quote Link to comment Share on other sites More sharing options...
Masoud Posted June 8, 2019 Author Share Posted June 8, 2019 13 hours ago, ikoon said: Hi Masoud, isn’t Attribute from Map SOP what you need? https://www.sidefx.com/docs/houdini/nodes/sop/attribfrommap.html Hi; AttributeFromMap, creates a point attribute from the color information found in an image (file), but I need to extract colors from texture used in a material, automatically. Actually, I need this in a digital asset. Thanks. Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 8, 2019 Share Posted June 8, 2019 (edited) Quote But I want to get texture from any input geometry, procedurally. @Masoud Please post reference here you have some Nice approach ...if ? https://www.sidefx.com/forum/topic/5905/?page=1#post-27566 Edited June 8, 2019 by srletak Quote Link to comment Share on other sites More sharing options...
Masoud Posted June 8, 2019 Author Share Posted June 8, 2019 I can't find any useful things. some links in that page are broken. Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 8, 2019 Share Posted June 8, 2019 @Masoud what effect do you want to achieve.... Please post reference Quote Link to comment Share on other sites More sharing options...
Masoud Posted June 8, 2019 Author Share Posted June 8, 2019 I want to use it as a part of my digital asset, so by connecting a geometry to input of my asset, it first converts input geometry to points using ADD SOP, then it needs to fetch and transfers colors from material to points. (Later I will use these colored points to make something else...) Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 8, 2019 Share Posted June 8, 2019 On 2017-05-12 at 12:05 PM, konstantin magnus said: Usually I would just copy-paste the nodes from a material network and reconnect their global inputs and outputs. As shaders work on pixels and not on points I don't think there is a direct way of exporting its calculations to points, but you could try baking out pixel maps and then import them with attribfrommap. @Masoud most important thing that i need.... you choose to left behind hm ....... Quote (Later I will use these colored points to make something else...) here is 6 ...and read please (pixels , values and other stuffs ) explore 6met.hipnc have a nice Day Quote Link to comment Share on other sites More sharing options...
Masoud Posted June 9, 2019 Author Share Posted June 9, 2019 (edited) Hi "srletak"; At first I want to thank you for the file. It's very helpful. The problem is I don't want to use a picture file to extract color information (like AttributeFromMap SOP, Pic(), VOP SOP color map, tex() and so on). I think when a geometry has a material (and a diffuse texture), we should be able to read the color information from it, right? I find a Mantra attribute that seems it can pass diffuse information to point : " vm_surface ", but I don't know how to use it.. Edited June 9, 2019 by Masoud Quote Link to comment Share on other sites More sharing options...
zarti Posted June 10, 2019 Share Posted June 10, 2019 On 6/9/2019 at 1:59 PM, Masoud said: Hi "srletak"; At first I want to thank you for the file. It's very helpful. The problem is I don't want to use a picture file to extract color information (like AttributeFromMap SOP, Pic(), VOP SOP color map, tex() and so on). I think when a geometry has a material (and a diffuse texture), we should be able to read the color information from it, right? I find a Mantra attribute that seems it can pass diffuse information to point : " vm_surface ", but I don't know how to use it.. hi Masoud , away from my workstation , but maybe this mixed technique could work ; bake wahtever info from your material into a texture map and then simply read those attributes with a truly_simple_and_pretty_editable AttribFromMap . as bonus points you can edit the bakedTexure with COP context and have a_lot_more control without going to rerender . dont know if this will do the work for your case , but just a suggestion .. .cheers 1 Quote Link to comment Share on other sites More sharing options...
