How could I transfer colors from material to points?
13 hours ago, ikoon said:
Hi Masoud, isn’t Attribute from Map SOP what you need?
https://www.sidefx.com/docs/houdini/nodes/sop/attribfrommap.html
Hi;
AttributeFromMap, creates a point attribute from the color information found in an image (file), but I need to extract colors from texture used in a material, automatically.
Actually, I need this in a digital asset.
Thanks.
I want to use it as a part of my digital asset, so by connecting a geometry to input of my asset, it first converts input geometry to points using ADD SOP, then it needs to fetch and transfers colors from material to points. (Later I will use these colored points to make something else...)
On 2017-05-12 at 12:05 PM, konstantin magnus said:
Usually I would just copy-paste the nodes from a material network and reconnect their global inputs and outputs.
As shaders work on pixels and not on points I don't think there is a direct way of exporting its calculations to points, but you could try baking out pixel maps and then import them with attribfrommap.
@Masoud most important thing that i need.... you choose to left behind hm ....... :rolleyes:
Quote
here is 6 ...and read please (pixels , values and other stuffs )
explore
6met.hipnc
have a nice Day
Hi "srletak";
At first I want to thank you for the file. It's very helpful.
The problem is  I don't want to use a picture file to extract color information (like AttributeFromMap SOP, Pic(), VOP SOP color map, tex() and so on).
I think when a geometry has a material (and a diffuse texture), we should be able to read the color information from it, right?
I find a Mantra attribute that seems it can pass diffuse information to point : " vm_surface ", but I don't know how to use it..
Edited by Masoud
On 6/9/2019 at 1:59 PM, Masoud said:
Hi "srletak";
hi Masoud ,
away from my workstation , but maybe this mixed technique could work ; bake wahtever info from your material into a texture map and then simply read those attributes with a truly_simple_and_pretty_editable AttribFromMap . as bonus points you can edit the bakedTexure with COP context and have a_lot_more control without going to rerender . dont know if this will do the work for your case , but just a suggestion ..
.cheers
