Maintain pivot locations from Maya using Alembic
ch3
Alembic packed geometry has a pivot intrinsic which sits on the centroid of each primitive. Is there a way to transfer an object from Maya and maintain the pivots that were set there?
thank you
and I was wondering if there is a way to
this might give you what you are after. Disclaimer: im reading packedfulltransform, not pivot. You can modify it if needed.
run over points
matrix m = primintrinsic(0,'packedfulltransform',@ptnum);
@orient = quaternion(matrix3(m));
//transform fix
matrix xform = primintrinsic(0, "packedfulltransform", @ptnum);
@P = {0,0,0};
@P *=xform;
//rotation in degrees
matrix matx = qconvert(@orient);
vector extracted = cracktransform(0, 0, 1, @P, matx);
v@rotation = extracted;
