It seems that point wrangle doesn't execute codes line by line, right?
Hi Guys;
In point wrangle SOP, when I select some points (in group tab) to apply the codes, the last selected point always overwrite the other ones. It seems that point wrangle doesn't execute codes line by line, right?
When I apply codes to points, one by one  (I mean a point wrangle for each selected point) it works fine.
Please take a look at my files (to visualize it, I applied my attribute to P.y ) :
Attribute Ramp_02.hip
The point wrangle runs once for every point, in order. So, your foreach is redundant.
The current point number is i@ptnum (an integer), the current points position is v@P (a vector), the current points floating point attribute named blahblah is f@blahblah.
If you want to set the y value in the P you can
float var = rand(i@ptnum);
v@P = set(v@P.x, var, v@P.z);
Edited by kleer001
clarity
functions that write to not current point like setpointattrib() or create new geometry like addpoint() etc. Are queued in point order and executed on a single thread after all multithreaded code
However that doesn't really matter in your case as much as the fact that in the single wrangle point() function will never read the updated "y" attribute, it will always read it from the input from so that's why 2 wrangles work for you
You can always flip your code to be other way around and therefore more multithread friendly
Like make all points look within the certain radius for points 17 and 306 and in the loop of found points they will change @y accordingly,  as each point will only change its own value it'll be able to read it back using @y within the for look as expected
  • Thanks 1
something like this:
vector P = @P;
string ptgrp = "17 306";
float radius = chf("MaxDist");
int pts[] = nearpoints(0, ptgrp, P, radius);
foreach(int pt; pts)
    vector ptP = point(0, "P", pt);
    float dist = distance(ptP, P);
    float invdist = fit( dist , 0, radius, 2, f@y);
    f@y = invdist;
Attribute Ramp_03_fix.hip
  • Thanks 1
