Filecaching simulation frame with different inputs overnight
I'm working with a wie simulation at the moment and would like to save out frame 300. This is ofcourse easlily done by saving out the frame with a file cache.
However,
The wires I'm imulating change patern per frame. So the input for the simulation changes when I try to run it.
I would like to save out the simulation frame 300 for all patterns. so say frame 1-10 I load in 10 diffrent patterns and want all of them to cache after 300 frames of simulation.
basically the end result would be: (where $F = 300)
Pattern-1-Simulation.$F.bgeo.sc
Pattern-2-Simulation.$F.bgeo.sc
Pattern-3-Simulation.$F.bgeo.sc
Ect.
I can manually do this by making the input static and waiting for the sim to run, but the sims take about an hour and a half and I would like to just leave that on at night.
I'd preferably like to avoid having to make 10 filecache nodes with 10 diffrent inputs and ROP-merge outputting them, though if this is the only way then maybe.
Any help?
