Hi guys,
I've recently (finally) started to use hbatch for rendering/saving out my files and it's a blessing.
So far everything has been running smoothly but last night one of my renders died on me.
I tried a slightly higher sim resolution and started it before leaving work, when I returned this morning I could see that slightly less than half had been simulated and real fast, only about 3-4 minutes each.
But then I simply got the "killed" feedback in my terminal with no further information, even though the render command was set to verbose.
Is there someway I can access why it was killed? Since they were running so quickly I don't believe the system ran out of resources but then again it is fully possible.
/ -> render -V obj/PYRO/explosionVdb
Rendering 54 frames ( from 1 to 54 by 1)
19:55:47 explosionVdb frame 1 (1 of 54)
19:55:47 explosionVdb frame 2 (2 of 54)
19:55:47 explosionVdb frame 3 (3 of 54)
19:57:18 explosionVdb frame 4 (4 of 54)
19:58:15 explosionVdb frame 5 (5 of 54)
19:59:34 explosionVdb frame 6 (6 of 54)
20:01:37 explosionVdb frame 7 (7 of 54)
20:04:52 explosionVdb frame 8 (8 of 54)
20:08:23 explosionVdb frame 9 (9 of 54)
20:11:32 explosionVdb frame 10 (10 of 54)
20:14:48 explosionVdb frame 11 (11 of 54)
20:18:12 explosionVdb frame 12 (12 of 54)
20:21:46 explosionVdb frame 13 (13 of 54)
20:25:28 explosionVdb frame 14 (14 of 54)
20:29:17 explosionVdb frame 15 (15 of 54)
20:33:19 explosionVdb frame 16 (16 of 54)
20:37:32 explosionVdb frame 17 (17 of 54)
20:42:00 explosionVdb frame 18 (18 of 54)
20:46:43 explosionVdb frame 19 (19 of 54)
Killed
I'm running Houdini Indie 17.5.258 on Linux Mint  19.1 Cinnamon.
Any and all help would be appreciated!
  • 2 months later...
On 15/7/2019 at 5:14 AM, Digistruct said:
Hi guys,
Killed
Any news? I have the same problem
