odd behavior of carve / pscale
Greetings,
I made a set of lines, assigned a random pscale attribute to points on one side of the lines. I copied spheres to the points, then I promoted pscale to the lines as a new attribute, then used that attribute to drive carve_SOP. But when I modify the attribute driving carve it modifies not only carve(first U) but the scale of these spheres as well.
carve_q.hipnc
That is correct, the CopyToPoint is interpolating that random pscale assigned at the end of each line. When you copy to the line, you inherit that interpolated pscale value. You can use an attributedelete, placed before the CopyToPoints, to remove pscale and the spheres won't change size anymore.
Edited by Atom
@Atom But I need that pscale :), the spheres should be of different sizes, what's odd and what I was asking about is, if I try to change the attribute which drives carve_SOP it also changes pscale of these points
If you have time, please look at the attached file. Try using a slider in the Null node named "CONTROLS".
carve will interpolate the attributes
so if one point has pscale of 1 and second 2, then if you carve in the middle the new point will have interpolated value in the middle of 1 and 2 so 1.5
then if you base your random on @primnum both points will have the same value so even interpolated value will be the same
