How do I skin connected curves?
domsewell
43 minutes ago, anim said:
you can try using PolyExpand2D SOP instead of Skin SOP
Hi @anim thank you for the reply this does get me 90% of the way there!
However, is there  a way to then get rid of these edges that are causing little triangles so that i can more easily select my connected edge loops?
Thanks again!
Not really using the polyExpand2d, you may also want to try the polyWire sop (and then flatten the result and removing the bottom)
another solutions is putting a grid under it, making a distance field of the curve on the grid, and then use a clip sop based on this value (by transforming the height using the distance field)
but this method creates an unaligned topology (which it sounds like you don't want)
