Shade volume attribute based on Volume Size
I'm using a basic smoke shader to shade volumes. I want to shade the scattering of the volumes perimeter depending on it's size; if the size of the volume is less then a specific size, then don't apply the scattering to the volume and only shade the volume using another type of basic smoke shader ?
Edited by CinnamonMetal
not sure if i understood correctly, but I'd try a switch SOP with an expression like sizeOfVolume < threshold to switch between 2 material SOPs
edit: or store the size of the volume in attribute that you read (bind) inside of the material followed by two-way switch, etc to drive whatever material parameters you want to drive based on that
Edited by 3dome
@Andrea Sbabo What do you mean it doesn't make much sense ?
The volume bounds is what I'm after, but it doesn't create an attribute which I can use in materials. I need to iterate over only volumes clusters which are within a specific size, and get only the perimeters or size of those volumes; that is what I'm not sure how ?
If some volume pieces are small, I want to ignore those, if the volume size is large; those are of which I want the size.
don't have H17 at hand but since volumeRasterizeAttribute uses volumeRasterizeParticles internally and at least in H16.5 volumeRasterizeParticles has those intrinsics I don't know why they shouldn't be available to you. I don't think SideFX removed them in 17, need to check later though
edit: in any case, this is Houdini so there's a million way to do things. How about convert your volume (to SDF) to polygons, measure area, sum up area -> get some value that way
Edited by 3dome
VolumeSDF SOP is what you mean by converting your volume to SDF, you can convert an SDF to polygons, I thought only if it's a VDB ?
I don't have a previous version of Houdini installed, if you can verify if they removed the intrinsic attributes ?
can't upload files and i usually work straight with VDBs but let's assume
1) you have a sphere -> isooffset
    Do you see the measured* intrinsics? (in H16.5 they are available)
2) convertvdb (to VDB, class Fog to SDF)
3) convertvdb (to Polygons)
4) from there all the measure and sum stuff (measure + attribpromote SOP)
will check this evening if I can see intrinsics after 1) in H17
Edited by 3dome
  On 7/23/2019 at 2:35 PM, CinnamonMetal said:
Yes.  Although converting it to polygons from an SDF removes all the intrinsic measure* attributes.
of course it removes them, because they are volume related intrinsic attributes. But if you see them, there's no need to convert to polys anyway. Just use them in your shader
