LaidlawFX
Enforce Prototypes @ptnum
Hello,
So doing some clean up on my vex code in a wrangle and I turned on Enforce Prototypes to remove a bunch of the hacks to get the code setup. The one thing I can not find out a cleanup for is to replace @ptnum with a non @ function.
Is the only way to declare it prior to the wrangle as another attribute? That just seems messy.  Even declaring before hands means you need @ptnum to source that attribute.
Thanks,
-Ben
Edited by LaidlawFX
@ptnum haunts
Share this post
Link to post
Here is an example file of using @ptnum to source a point attribute that errors out when enforce Prototype is on.
int id = point(0,"id",@ptnum);
setpointattrib(0,"Cd", @ptnum,id);
Upstream of that I have an attribute create that does a basic.
i@id=@ptnum;
ptnum.hip
Share this post
Link to post
i@id=@ptnum;
ptnum.hip
Yeah in that case you need to declare @ptnum at the top. So:
int @ptnum;
Think of it as a key. If you write @ptnum further down, it will take a look to see if it's allowed to accept that. If it isn't declared, or if you make a typo (@ptnmu) it will error because it isn't allowed.
I don't think you can get rid of @ altogether, but you can add it to a variable to get rid of it further down:
int @ptnum;
int pointnum = @ptnum;
  • Thanks 1
Share this post
Link to post
Thanks for that. I just re-read what you said and that link you sent. Had to do a double check and it follows the pattern in cvex, too. It's been a long time since I looked at vex like this.
cvex
obj_geo1_pointvop1(int ptnum = 0;
        export int Cd = 0)
    // Code produced by: bind1
    Cd = ptnum;
Thanks again.
Found the declaring part in the docs again, too.
https://www.sidefx.com/docs/houdini/vex/snippets.html#declare
Edited by LaidlawFX
Found another link for declaring for future people.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
