catchyid Posted July 26, 2019 Share Posted July 26, 2019 Hello, [Houdini 17.5] I have Bullet simulation of a concrete building. I have two fracture levels (big chunks and smaller pieces inside them). At some point I apply forces and let big chunks fall. My goal is break these chunks even further when hitting the ground (not a complete disintegration, but instead some big chunks break into 3 or 4 smaller chunks). My biggest challenge is choosing "good" constraints strengths for the second fracture such that they break on the ground impact. Currently, I am doing this by trial and error, but it's not efficient. My question: Is there any way to guess/compute constraint strengths to achieve such result? One idea is to sim first, measure impacts on constraints and then use them as an initial guess ( for constraints strength), but this is not always working (plus it's an iterative process)! Another idea is to force the second constraints fracture to break on impact (e.g. using geometry wrangler), but I am afraid this will give always the "same" results, while I am hoping for some organic shapes due to impact ... Quote Link to comment Share on other sites More sharing options...
DonRomano Posted July 26, 2019 Share Posted July 26, 2019 Did you try to compute randomized constraint strength at the sop level ? Maybe in a wrangle you can type : f@strength = fit01(rand(@cluster), ch("min_strength"), ch("max_strength")) So it can multiply the strength in the glue conrel node based on the one you defined at sop level. I don't know if it works but you can give it a try Cheers Quote Link to comment Share on other sites More sharing options...
catchyid Posted July 27, 2019 Author Share Posted July 27, 2019 Thanks Romain I already have randomization in place, but the question is what is the right min/max strength? Currently I guess them by trial and error, so the main point of my question: instead of simming and trying different values, is there another way to compute these min/max values? Quote Link to comment Share on other sites More sharing options...
tamagochy Posted July 27, 2019 Share Posted July 27, 2019 Only way it tests with smaller amount to fast find proper values. Quote Link to comment Share on other sites More sharing options...
DonRomano Posted July 27, 2019 Share Posted July 27, 2019 7 hours ago, catchyid said: Thanks Romain I already have randomization in place, but the question is what is the right min/max strength? Currently I guess them by trial and error, so the main point of my question: instead of simming and trying different values, is there another way to compute these min/max values? Well, make wedges and you'll see, with tops it's easy now ! Another way to create cool chunks is to create another constraint network and use the bullet soft constraint with a break threshold with the distance attribute. I'm using it for destruction and it adds a really cool effect, with bigger chunks breaking into smaller and bending pieces. Otherwise, you can check the maximum force value applied to your constraints when simulating (in the geo spreadsheet) and you can use it as a reference, to create a breakforce attribute on your constraints at sop level, and then inside the dops, use a sop solver to remove those constraints using vex, by using the force attribute which exists on your pieces. Connect the glue into the 1st input and the rbd geo into the 2nd input, and wrangle this : @forcept = nearpoint(1, @P); @force = point(1, "force", @forcept); @mag = length(@force); if(@mag > @breakforce){ removeprim(0, @primnum, 1); } Cheers, Quote Link to comment Share on other sites More sharing options...
catchyid Posted July 28, 2019 Author Share Posted July 28, 2019 Thanks Romain and Andrii from our discussions, it seems that there is no "magical" way to guess these values, the only way is to sim, measure impulses on constraints and use these values as a reference... Once more, thank you guys Quote Link to comment Share on other sites More sharing options...
