An_pi Posted July 27, 2019 Share Posted July 27, 2019 I have 3 entries in a wedge (each 48 frames) that I would like to render out in 3 different videos, instead of render all iterations out in one video. How can I do that? Quote Link to comment Share on other sites More sharing options...
bunker Posted July 28, 2019 Share Posted July 28, 2019 (edited) I tried the partitionbyindex but didn't get it to work after all, anyone? Edited July 29, 2019 by bunker Quote Link to comment Share on other sites More sharing options...
loudsubs Posted August 2, 2019 Share Posted August 2, 2019 Guessing here, haven't tried this for writing videos - Partition by attribute, and make sure the attribute you're wedging is in the filename. Then you should get 3 different files. Quote Link to comment Share on other sites More sharing options...
kleer001 Posted August 2, 2019 Share Posted August 2, 2019 (edited) Why do you want separate videos? I'm doing something similar but combining the sequences with an ImageMagick Montage TOP as well and labeling for current variable value. See attached for the full biz. topstest_02.hipFetching info... Edited August 2, 2019 by kleer001 moar info Quote Link to comment Share on other sites More sharing options...
