CinnamonMetal Posted July 29, 2019 Share Posted July 29, 2019 How can I put UV's within range as Mari is complaining my UV's are out of range due to the UV uv-unwrapper which was used to unwrap the UV's. Quote Link to comment Share on other sites More sharing options...
davpe Posted July 30, 2019 Share Posted July 30, 2019 i suppose you only miss edge padding. in that case easiest thing is to use UV trasform SOP and simply scale your uvs down a bit. you can also use wrangle SOP and remap the uv range with fit function. if you don't need to keep the layout then UV layout will do a good job arranging messy uvs into a udim tile. Quote Link to comment Share on other sites More sharing options...
Atom Posted July 30, 2019 Share Posted July 30, 2019 (edited) Make sure you use SPACE-5 in the viewport to visualize the layout of your UVs. Mari NC only supports one UDIM tile so you have to fit all your UVs within that first box. Edited July 30, 2019 by Atom Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted July 30, 2019 Author Share Posted July 30, 2019 (edited) @Atom I'm using the commercial version. @davpe When you say UV layout, I assume you mean UV layout in Houdini, not another program ? Although edge padding probably is the issue with Mari. Edited July 31, 2019 by CinnamonMetal Caught on late what Atom meant by NC ;-) Quote Link to comment Share on other sites More sharing options...
