domsi Posted August 11, 2019 Share Posted August 11, 2019 Hey, i am fairly new to houdini and especially to redshift. I have a setup with particles and want some particles to be emitted by a specific distance. I use the particle color as base color and want my attribute to drive the emission strength. If i use mantra everything works fine. Couldnt find any solution. Cheers and thanks, dom Quote Link to comment Share on other sites More sharing options...
Atom Posted August 12, 2019 Share Posted August 12, 2019 Make sure you have enabled global illumination. You will get no emission from Redshift, until you do. Quote Link to comment Share on other sites More sharing options...
jonidunno Posted August 14, 2019 Share Posted August 14, 2019 When you do emission with redshift you can do it two ways: One - Threw the material in which case you need to lower the diffuse weight and up the emission weight. Second way - Would be to do it through the incandescent. attached is an example. Hope it helps! jl_rs_particleColor_01.hipFetching info... 1 Quote Link to comment Share on other sites More sharing options...
