some issue about push points to the surface (solved)
akaliln
hi everyone, I have some issue about to push points to the surface. I use volume gradient and volume sample to detect the distance to the surface. The result is worked but not perfectly on the surface. and also have a bit shaking.
I try to change the voxel size of vdb. but the issue still exist.
Is there anyone can help me to have a look the file please?  thx
push_points_issue.hipnc
Edited by akaliln
the jittering is caused by your popvop1 as you are constantly flipping the tangent v vector every frame
- to fix that you can just swap the inputs on the cross2 node
- also on your popvop_modify_P_and_drag node enable normalize1 node
- lastly, connect your two popvops after everything else, otherwise solver may still move your points into 'collisions' which will not be corrected for
Edited by anim
On 2019/8/14 at 8:42 PM, Atom said:
I'm not sure why you're not just creating a collision object?
You can also look into the minpos() function. which will help keep points on a surface.
http://www.tokeru.com/cgwiki/index.php?title=HoudiniDops#Pop_stick_to_surface
Hi thanks for your reply. I tried to understand how the volume gradient and volume sample node work, and read some example on the internet.
thanks for your link info, there are also have some good way to keep points on the surface.
thank you very much!! the problem solved. I tried to fixed all what you mentioned about and it's working perfect after that!! thanks for your help.
