netherknight Posted August 26, 2019 Share Posted August 26, 2019 I'm running into an issue. I'm using the convert node to change my wires to NURBS. However, when I render these out it renders them as if the conversion hasn't happened. Is there a good reason as to why this is happening? Quote Link to comment Share on other sites More sharing options...
anim Posted August 26, 2019 Share Posted August 26, 2019 instead of converting them to NURBS you can check Render/Geometry/Render Polygon Curves As Subdivision on your object or add that property to the shader Quote Link to comment Share on other sites More sharing options...
Nicholas Ralabate Posted March 4, 2020 Share Posted March 4, 2020 I'm not sure if this is a bug or not (18.0.391), but I noticed that "Render Polygon Curves As Subdivision (Mantra)" only works if you also have "Render Polygons as Subdivision (Mantra)" enabled. Quote Link to comment Share on other sites More sharing options...
anim Posted March 5, 2020 Share Posted March 5, 2020 works for me without the need to have both enabled, same version just note "Render Polygon Curves As Subdivision (Mantra)" works for open curves, closed curves render as polygons (not ribbons) and those will use only "Render Polygons as Subdivision (Mantra)" property 1 Quote Link to comment Share on other sites More sharing options...
