To create a round fencing around house, every cube is aligned in same direction, how can we make to face around the circle like real fence
you need to compute a tangent in your curve/circle in order for Houdini to copy your boxes along the curve with the right alignment. With attribute randomize you can change many properties of your instances before copying.  One of the many ways that you can change attributes btw.
I would recommend reading Matt joy of vex
http://www.tokeru.com/cgwiki/index.php?title=JoyOfVex
Simplefence.hipnc
Edited by Sepu
  • Thanks 1
