How to emit smoke from fractured objects
fictionfxartist
Hi all,
I've been trying to create a structure destruction by exploding some building.
I created RBD simulation, then i moved forward to create the smoke but as soon as i applied the debris shelf tool the whole model changes into smoke and doesn't even move.
I also tried to do it manually but same problem occured.
I want it to emit smoke as soon as model breaks into pieces & I am not able to do it. If some have any knowledge regarding the please help.
Thank You.
Personally I would stay away from shelf tools. Most of the time they don't do what you want when you combine them. Try to understand what they do instead.
Here is a blueprint of what you are trying to do, maybe it helps:
https://hdbp.io/l7RvfsKT
It's a multi-step approach. First create debris points, emit from them, then use the emitted points as a pyro source.
Edited by ChrBohm
