clifford torus effect
angelous4x
Hi @angelous4x  you have an idea I have an idea, + + =  maybe.
transform before /$PI *2 = x and y
Confuse a cat
play with this and your idea.:wub:
complex math find
http://wordpress.discretization.de/houdini/
//q=(1+i+j+k)/2  must be 1 Möbius strip
float cos = v@P.z;
float sin = v@P.x;
float r = v@P.y;
float c_sqr = pow(cos,1) -pow(sin, 1);
float s2 = 1*sin*cos;
vector C = set(c_sqr, 0, s2);
vector B = {0, 1, 0};
vector N = cos * C + sin * B;
v@P = C + r * N;
//Sudanese surface.
vector4 gamma(float t) {
    return set(cos(t), sin(t), 0, 0);
vector4 N(float tau; float t) {
    float tau_t = tau * t;
    return set(0, 0, cos(tau_t), sin(tau_t));
vector4 f_tau(float tau; float x; float y) {
    return cos(y) * gamma(x) + sin(y) * N(tau, x);
vector sigma(vector4 v) {
    return set(v.x / (1 - v.w), v.y / (1 - v.w), v.z / (1 - v.w));
float tau = chf("tau");
vector4 q = {1, 1, 1.5, 1};
q /= length(q);
v@P = sigma(qmultiply(f_tau(tau, v@P.x, v@P.y), q));
or just use file from Matt Ebb a long time ago
http://mattebb.com/blog/
Edited by srletak
  • Like 2
Here is another approach (definition somewhere from web).
  • Using the clifford torus defintion from wiki.
  • Using a 4d rotation (in my case between the first and the last component)
  • applying a stereographic projection, to map from 4d space back into 3d space
I'm not sure if this is correct, because it looks a bit weird for me ...
clifford_torus.hipnc
