Sierpiński triangle with VEX
Zunder
4 minutes ago, Aizatulin said:
Here is an approach using 3 for loops (the inner can be avoided).
I do not really like this approach, because I'm pretty sure, that there much more elegant solutions out there (even without recursion).
sierpinski_vex.hipnc
Thank you for your reply.
This is quite interesting approach, but it's really confusing to be honest. I found this page https://sdm.scad.edu/faculty/mkesson/tech312/wip/winter18/meredith_omalley/sierpinski/index.html , and right now trying to adopt the code for VEX. Do you think it will work out ?
