Jesper Rahlff Posted September 30, 2019 Share Posted September 30, 2019 Hey guys. Now and then the attached happens to my vector parameters. Never found out if it is a bug or something I accidentally triggered. Notice that my offset has been combined into 1 slider with a #2 next to it Anyone know how to solve this? Cheers Quote Link to comment Share on other sites More sharing options...
anim Posted October 1, 2019 Share Posted October 1, 2019 usually, just put cursor in that field and hit Tab until you get back to 3 fields, so should be twice for your case Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted October 1, 2019 Author Share Posted October 1, 2019 3 hours ago, anim said: usually, just put cursor in that field and hit Tab until you get back to 3 fields, so should be twice for your case Thanks for the suggestion. That does not seem to work for me unfortunately Quote Link to comment Share on other sites More sharing options...
3dome Posted October 1, 2019 Share Posted October 1, 2019 has happend to me quite a few times as well...utterly annoying. I used to know a way of reliably getting it back to 3 values, but forgot Luckily it didn't happen for quite some time now but I think I used to Alt-LeftClick the parameter name to set a keyframe (maybe scope it aswell) to make it "re-draw" the UI Quote Link to comment Share on other sites More sharing options...
mzo Posted November 11, 2021 Share Posted November 11, 2021 On 9/30/2019 at 5:00 PM, anim said: usually, just put cursor in that field and hit Tab until you get back to 3 fields, so should be twice for your case This tip is gold. You can't imagine how many times I got frustrated with this silly but very annoying issue. Quote Link to comment Share on other sites More sharing options...
magnetoflow Posted December 7, 2021 Share Posted December 7, 2021 Neither of those techniques worked, but I noticed if you right click on a node and select parameter, it will pop up a new window that represents the old window, but with the ui fixed Quote Link to comment Share on other sites More sharing options...
