creating texture files procedurally (and backing to desk)
Hi,
I don't have any experience about this topic, so my question could be a total dumb :)
I have a 3d model (i.e. alembic) with uv. My goal is to paint in 3D some colors on the model mesh (the painting is done procedurally) then save a uv map containing the procedural painting (let's say as .png). The goal is to load and use this newly generated texture in another shading program. Is this possible and how?
Thanks,
Hi Khaled,
you can transfer geometry shapes and attributes to pixel maps with VEX functions such as uvsample(), xyzdist(), primuv(), volumesample() and nearpoint() inside a VOP2COP Generator.
I attached examples covering:
  1. Transferring attributes
  2. Blending image textures by attributes
  3. Tracing points
  4. Tracing closed 2D curves
  5. Tracing open 3D curves
  6. Tracing flattened meshes
  7. Sampling volumes
Combining those should give you a good variety of procedural image painting options, either directly or for masking:
image.png.9af8ace80f766b0332dd7251e4b2be79.png image.png.8d159850d9f7528f95876202120fb97e.png image.png.48aadf95191b07b9b2d403358d2358e6.png image.png.6eb429d33c6217e0256da777a706ee0d.png image.png.68890a47d6f7b507b2c6704ff12f466c.png image.png.e99211d20ddb00d7ab6f93680e7bb875.png image.png.2be0b4ab03e4d0ad7c5094c60772c55e.png
Another option esp. for baking ambient occlusion or even rendering perspective views would be raytracing with the intersect() function.
GEO_to_COPs.hipncFetching info...
Edited by konstantin magnus
  • Like 6
  On 10/4/2019 at 1:04 PM, konstantin magnus said:
Hi Khaled,
  3. Tracing points
  7. Sampling volumes
Edited by vinyvince
  • 2 years later...
Hi Khaled,
  3. Tracing points
  7. Sampling volumes
GEO_to_COPs.hipncUnavailable
The snippest to grab N attribute from the obj and do the dot product mask doesn't seem to behave like it should, Doesn't look like reading N but i don"t see any error in the following snippet, did i miss something?
Im under H19, py3:
string geo_mesh = 'op:/obj/geo_1_textures/OUT'; // geometry path
vector uv_tex = set(X, Y, 0.0); // texture space
// assign image textures to UV coordinates
vector tex_0 = colormap(tex_A, uv_tex);
vector tex_1 = colormap(tex_B, uv_tex);
vector N = uvsample(geo_mesh, 'N', 'uv', uv_tex); // transfer normal attributes from geo
float mask = clamp( dot(N, {0,1,0}), 0.0, 1.0); // create mask based on normals direction
mask= pow(mask,0.8);
vector tex_diff = lerp(tex_0, tex_1, mask); // blend textures dependent on mask
vector color = tex_diff; // assigns texture to color vector
assign(R, G, B, color); // color vector gets assigned to R, G and B color components
Yes Konstantin.
It's just when i blur the normal or even add a noise to it, the mask doesn't seem to react.
Very basic but i can't get the proper mask in the the Cop snippet right...
Off course i can't get it in SOP, but i will rather like pixel than point :)
Edited by vinyvince
