Redshift causeing flipbook mplay to crash?
midicon
Hey, Anyone else having an issue with 17.5.258, where redshift 17.5.229 rendering works fine... but my flipbooks (Mplay) crash? I can render with Mplay but when I go to flipbook anything it leaks mem and them flipbook crashes saying it can't display images. If I remove the env variable pointing to the taskbar, flipbooks work? if I use an earlier redshift plugin version (i.e. 17.0.506), the self and flipbooks work fine... but there isn't the same functionality. There doesn't seem to have the RS proxy output. Please let me know if you have run into this or an issue similar.
Thanks
  • 3 months later...
  • 3 months later...
  • 2 weeks later...
hi
i had the same problem. the only solution i found is to disable redshift. In the houdini.env file, just add # to the beginning of each line.
When you want to use redshift you must remove it and restart the soft.
