Use color information to deform a geometry ??? [attribfromvolume] > [peak]
NodeBrain
If you want to store the displacement between two objects with the same topology, use
v@Cd = v@opinput1_P - v@P;
Apply the displacement with
v@P += v@Cd;
In case the topology differs, shoot rays:
vector pos_hit;
vector st_hit;
int prim = intersect(1, v@P, v@N * 5.0, pos_hit, st_hit);
vector dir = pos_hit - v@P;
v@Cd = dir;
You will loose high frequency surface details, though.
displacement.hipnc
Edited by konstantin magnus
Thanks a lot for your help!
It's only been 4 days that I try to learn the software.
I did not start to learn the code and I did not know what to do to make it worked.
Thank you Drughi for your line of code ... It would be necessary to change what we call the OutPut of the "Attribfromvolume1"?
(And thank you very much Konstantin Magnus for your help. As soon as I have a more advanced level, I try to do your method).
As I explained, I've just started on this software (hard to learn) and I did not find the tutorials that really explain the philosophy of this software.
If you have links to tutorials.
I had worked a lot with the hypershade of maya (almost 20 years ago), and I did not find the same logic of connection ...
Thanks
