CinnamonMetal Posted October 13, 2019 Share Posted October 13, 2019 I want to create my own custom image planes (AOV) in Houdini; I'm binding out the layer using a bind export to the surface context then I'm connecting that to a Set Layer export, giving it the same name as from the bind export then connecting the layer to another vop which accepts a layer connection. Although when I render I get a; Invalid declaration type for variable & the AOV doesn't show ? Quote Link to comment Share on other sites More sharing options...
nuki Posted October 13, 2019 Share Posted October 13, 2019 did you set the type in the bind export correctly? There is a setting to inherit it from the input value. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 13, 2019 Author Share Posted October 13, 2019 11 minutes ago, nuki said: did you set the type in the bind export correctly? There is a setting to inherit it from the input value. If your referring to the setting Use Input Value If Not Bound, since I'm plugging the Parameter bound into the other input of the Set Layer Export; there is no need for use the Use Input Value If Not Bound setting. Quote Link to comment Share on other sites More sharing options...
jamesr Posted October 14, 2019 Share Posted October 14, 2019 All you should really have to do is bind export from the shader. Render this bad boy out and let me know if that's what you're after. aovs.hip Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 15, 2019 Author Share Posted October 15, 2019 3 hours ago, jamesr said: All you should really have to do is bind export from the shader. Render this bad boy out and let me know if that's what you're after. aovs.hip Not quite, when using setLayerExport in materials you can write out branches to an AOV\extra image plane; what you've done is use an attribute noise sop and create an attribute from the noise, two different things. Quote Link to comment Share on other sites More sharing options...
jamesr Posted October 15, 2019 Share Posted October 15, 2019 You asked how to create your own AOV, which is what's demonstrated in the demo scene. I use some arbitrary noise to write out to their own image planes. Did you hit render and look at the extra image planes? You don't need set/get layer export to write out aovs. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 15, 2019 Author Share Posted October 15, 2019 6 hours ago, jamesr said: You asked how to create your own AOV, which is what's demonstrated in the demo scene. I use some arbitrary noise to write out to their own image planes. Did you hit render and look at the extra image planes? You don't need set/get layer export to write out aovs. Watch this until 33:00; I've created a bind_export vop within materials and hooked up a colorMap to the bind_export then I've tried both a SetLayerExport and a GetLayerExport. Although in the video only a setLayerExport is shown, but in Houdini 17 only a getLayerExport has the same functionality as the setLayerExport had in Houdini 16 in either case it doesn't work ? Also unless someone knows otherwise, you can't write BSDF's to an AOV\Extra Image Plane, they can only be Vector3 ? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 17, 2019 Author Share Posted October 17, 2019 I hope someone can help me understand what is shown in the segment mentioned; I must know. Quote Link to comment Share on other sites More sharing options...
jamesr Posted October 17, 2019 Share Posted October 17, 2019 (edited) Are you using layer mixing in your material? Or are you just trying to write custom aovs? Edited October 17, 2019 by jamesr Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 17, 2019 Author Share Posted October 17, 2019 4 minutes ago, jamesr said: Are you using layer mixing in your material? Or are you just trying to write custom aovs? Write custom AOV. Quote Link to comment Share on other sites More sharing options...
jamesr Posted October 17, 2019 Share Posted October 17, 2019 And the demo file doesn't work? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted October 17, 2019 Author Share Posted October 17, 2019 It doesn't work in the way I want to create an AOV which is another way that is mentioned in the video. Quote Link to comment Share on other sites More sharing options...
