Exporting Material Diffuse Animation
Hi there,
Im stuck on this problem im facing. I have created a material which basically shows the wetmap (collision history) of my flip fluid colliding with my static object. The issue I face is how to export this diffuse material as an animated image sequence in the correct uv space and unwrap of the static object model. i want to use this in maya as a shader.
If anyone has any suggestions i would be thankfull forever :).
Cheers.
