90okm Posted October 23, 2019 Share Posted October 23, 2019 (edited) Hi ! I've got hqueue farm set up on linux machines. i use it only for simulations Sometimes i get hip files for simulation that contain various number of operators which are not needed for sim (i.e. some custom ROPs, materials etc.) BUT ! when a client loads this hip file it warns that it can not load specific OTL and refuses to load hip. Let's say i have a scene with geo node that has reference to some Redshift material in its 'material' parameter. but i don't want to render this. i just want to simulate and write geometry to disk. But hqueue refuses to do that because it can not find redshift otls .... Is there a way to force houdini to ignore things like this....????? So you can not find otl!!!!....nevermind. just simulate...you do not need redshift to simulate dop network.... upd: when i connect to client via ssh and start hbatch in terminal - it works.....it loads file, claims that can not recognize node types...but simulation works when i start it with the command manually (render -V rop_node).. why hqueue can not do that and just fail the job ??? Edited October 23, 2019 by 90okm Quote Link to comment Share on other sites More sharing options...
90okm Posted October 24, 2019 Author Share Posted October 24, 2019 SOLVED i've just set up redshift DEMO as a loopback and all necessary CUDA libs now hqueue client loads hip without any errors Quote Link to comment Share on other sites More sharing options...
