char Posted October 25, 2019 Share Posted October 25, 2019 Hi all, Going to get straight to my point here. I've been trying to wrap my head around a proper workflow for achieving good timings explosion and smoke simulations. Let's say in this example explosion , the look and the timings are great. My ideas are either having proper advection methods, using animated divergence, injecting high velocities for first few frames and then using drag to slow it down or (last idea I had today) using Time Warp node, to retime the whole explosion caches to your preferred look. Could someone experienced enough drop a few lines around what the approach of an FX artist is whilst tackling a explosion in a shot for a film or just in general. Am I going down the right path with these methods or is it completely off? Thanks 1 Quote Link to comment Share on other sites More sharing options...
Yon Posted October 25, 2019 Share Posted October 25, 2019 sourcing high velocity will stretch your vel field out and cause mushroom shapes that would need increase substeps to resolve. for initial punch it is better to use gas repeat 1 Quote Link to comment Share on other sites More sharing options...
char Posted October 25, 2019 Author Share Posted October 25, 2019 I'm aware of that problem, countering it with masking and disturbance fields would probably help I assume. Is the video you provided really the only "efficient" method (I've seen it before) of actually getting that initial punch and then letting it slowly drift with drag? Quote Link to comment Share on other sites More sharing options...
Drughi Posted October 26, 2019 Share Posted October 26, 2019 If you don't have collisions involved you can also retime using the gas upres. Quote Link to comment Share on other sites More sharing options...
