Custom Raytracer in COPs
konstantin magnus
  • 1 year later...
  • 6 months later...
A quick example for raytracing through several layers of texture opacity:
image.png.c0f39b269aaa177153010a947bdf1a10.pngimage.png.f4ab232d7970175dc26f08a61105ea5c.png
string image_path = chs('image_path');
vector uv = relbbox(0, v@P);
vector4 clr = colormap(image_path, uv);
v@Cd = vector(clr);
f@Alpha = clr[3];
vector pos[];
int prim[];
vector uvw[];
intersect_all(1, v@P, v@N * 1e3, pos, prim, uvw);
vector color_sum = 0.0;
float alpha_sum = 0.0;
foreach(int i; int pr; prim){
    vector color = primuv(1, 'Cd', pr, uvw[i]);
    float alpha = primuv(1, 'Alpha', pr, uvw[i]);
    float mask = alpha * (1.0 - alpha_sum);
    color_sum += color * mask;
    alpha_sum += mask;
    if(alpha_sum >= 1.0) break;
v@Cd = color_sum;
f@Alpha = alpha_sum;
raytrace_alphas.hiplc
Sexy fish @konstantin magnus
Something i have been thinking, is to be able to sample in 3d space all decals or texture bombing stuff so the mesh will inherit the normal from then, and dynamically update build its normal map or eight color from that.. Do you see what i mean @konstantin magnus?
I know i could sample the color and so in point space, but obviously everyone will prefer not to have a very high density mesh to get correct sampling result, so i picture this more on the shader based context... Am i right ?
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
  • 9 months later...
