art3mis Posted December 1, 2019 Share Posted December 1, 2019 By default when you put down a DOP I/O and use the FLIP Fluid preset it gives the attached. Is this complete and correct? ie the left column is all blank Quote Link to comment Share on other sites More sharing options...
DonRomano Posted December 1, 2019 Share Posted December 1, 2019 The left column is blank because it's used if you want to import the field of a precised object (which you have to precise there). Here, you are importing the fields for the object precised in the DOP Node textfield, so there is no need to use the left column, that's why it's left blank. Cheers, Quote Link to comment Share on other sites More sharing options...
art3mis Posted December 1, 2019 Author Share Posted December 1, 2019 Makes sense, thanks. Quote Link to comment Share on other sites More sharing options...
