fabsberry Posted December 11, 2019 Share Posted December 11, 2019 Hey dudes, I'm trying to build a simple smoke solver from scratch to understand more how they work. I created a simple setup with density, temperature and buoyancy. Now I want to add a second velocity volume as a force to my simulation. But when I add the force, the velocity is increasing massively in a few frames. I have to mix my force with the existing velocity but I don't understand how to do this my_solver.hiplc Quote Link to comment Share on other sites More sharing options...
fencer Posted December 11, 2019 Share Posted December 11, 2019 (edited) Maybe you forget "Gas Project Non Divergent", check this: Edited December 11, 2019 by fencer 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted December 12, 2019 Share Posted December 12, 2019 (edited) On 12/11/2019 at 4:34 PM, fabsberry said: But when I add the force, the velocity is increasing massively in a few frames. I have to mix my force with the existing velocity but I don't understand how to do this Expand To do this the right way take a look into the gas wind. The quick and dirty way is to simply advert the fields with you force, but this is not recommended, because it leads to wrong velocities. Edited December 12, 2019 by Drughi 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted December 12, 2019 Share Posted December 12, 2019 my_solver.hipnc 1 Quote Link to comment Share on other sites More sharing options...
fabsberry Posted December 12, 2019 Author Share Posted December 12, 2019 Thank you, Johannes! The gas wind node was a great hint. I found an additional mistake that I made: the border type of my fields was set to streak but it had to be constant. my_solver_fixed.hiplc Quote Link to comment Share on other sites More sharing options...
