opacity map in Principled shader
The color texture doesn't have alpha, there is a separate opacity map (black and white).
In the principled shader I can see the "use texture alpha", but that assumes that my texture has an alpha which is not the case. While waiting for Side FX to add a convenient "use opacity texture", how would you plug this texture in the complicated network of things in the kitchen of the principled shader.
There is a video showing something like that, but it dates back to the shops days, I couldn't follow, the network has changed.
20 hours ago, anicg said:
... While waiting for Side FX to add a convenient "use opacity texture"...
there is Textures/Opacity/Use texture on principled shader
but if it wasn't you can also just connect texture VOP to opac or opaccolor input
