davidyannick Posted December 14, 2019 Share Posted December 14, 2019 I have a boolean and I'd like to extract a shape from this one, to create a new piece. Now I can do it (red one) but I'd like to have something more precise like the blue Is it possible ? thanks ray.hiplcFetching info... Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted December 14, 2019 Share Posted December 14, 2019 Hi, in "matchsize1" turn on scale to fit. in "ray1" turn change method to project rays and set direction from vector to (0,-1,0) turn off "facet1" ray.hipnc 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted December 14, 2019 Author Share Posted December 14, 2019 On 12/14/2019 at 9:36 AM, Aizatulin said: Hi, in "matchsize1" turn on scale to fit. in "ray1" turn change method to project rays and set direction from vector to (0,-1,0) turn off "facet1" ray.hipncFetching info... Expand ok thanks for your help 1 Quote Link to comment Share on other sites More sharing options...
anim Posted December 14, 2019 Share Posted December 14, 2019 or if you want to be precise, keep top polys of your shape and boolean with a plane to create seam ray_boolean_seam.hiplc 3 Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted December 20, 2019 Share Posted December 20, 2019 or you can create a curve on the object. use the object as second input of the curve and it will be projected onto the object. Quote Link to comment Share on other sites More sharing options...
Herve Posted December 21, 2019 Share Posted December 21, 2019 On 12/20/2019 at 1:34 PM, Houdini7 said: or you can create a curve on the object. use the object as second input of the curve and it will be projected onto the object. Expand Hi, Jumping on this if I may... I tried it, and can't seem to get the intended results. I tried connecting the input of a curve node to the output of a tube/grid/etc, before or after I start drawing the curve points, and I get no snapping to the input mesh. I tried transforming/moving the input mesh too, no change. What am I missing? Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted December 21, 2019 Share Posted December 21, 2019 On 12/21/2019 at 10:33 AM, Herve said: Hi, Jumping on this if I may... I tried it, and can't seem to get the intended results. I tried connecting the input of a curve node to the output of a tube/grid/etc, before or after I start drawing the curve points, and I get no snapping to the input mesh. I tried transforming/moving the input mesh too, no change. What am I missing? Expand The curve sop can accept another curve as input, then it will snap to this curve (sometimes needed, but not what you want). But the drawcurve sop works like you would expect. Try it. 1 Quote Link to comment Share on other sites More sharing options...
Herve Posted December 21, 2019 Share Posted December 21, 2019 oh I see. 'drawcurve' sop, indeed. Thank you! Quote Link to comment Share on other sites More sharing options...
