Bullet constraint
turas29
here you are...but pinning the top is a bit weird, innit ?
vu_statueCrumble_odforce.hipnc
EDIT: since I pinned at the bottom checkbox you can uncheck the Active above it, that's superfluous.
Also, I couldn't be stuffed waiting around for 3 levels of fracturing, so you should reenable them, when testing just deal with SIMPLE cases first, get that going then jazz it up.
Edited by Noobini
