Masoud Posted January 5, 2020 Share Posted January 5, 2020 Hi; To modify the attributes of the points, in a Vellum simulation, I add a "Point Wrangle" before "Vellum Cloth" SOP, But it doesn't work. Is this a right way to modify vellum points sim? Thanks for helping. Quote Link to comment Share on other sites More sharing options...
anim Posted January 5, 2020 Share Posted January 5, 2020 yes, to modify initial state properties of the cloth you can do it this way just make sure you set the Bend Stiffness on Vellum Constraint to Scale By Attribute and put your attribute name in there 1 Quote Link to comment Share on other sites More sharing options...
