PastaPesto Posted January 17, 2020 Share Posted January 17, 2020 Hello I am making a procedural designing asset/tool, for a wooden house. Wall and floor frames are being generated in refence to the foundation size. Larger the foundation, more boards is being created for the walls and floor framing. Everything is made with just linking a box size parameters to a "slider" on a parameter interface. Then copied, transferred and merged, to form a simple house frame. Is there a way to make a counter on the parameter interface, that displays the number of boards(primitives?) being used? Thanks /PP Quote Link to comment Share on other sites More sharing options...
rbesca Posted January 17, 2020 Share Posted January 17, 2020 hey do you mean like this? you can create a detail string that references your copy amount, click on it in the detail debug popup to get a popup in the viewport so you can see the amount. if you name the attribute with the string you'll get a warning, not sure what kind of issues you might get with that but it doesnt seem necessary. hope this helps showparameter.hiplc Quote Link to comment Share on other sites More sharing options...
PastaPesto Posted January 18, 2020 Author Share Posted January 18, 2020 Hey rbesca Thanks for your response I am making copies of boards on every 60cm along the house wall, and not using copy to points.. so its bit different setup, and im not skilled enough in houdini to make use of your method in my setup. I have attached a simple version of my wall builder and a image to show where i would like to have a counter on parameter interface. Not sure if it possible at all.. but i think it would be a nice feature, and the data is right there, in the geometry spreadsheet, i just cant figure how to implement it. Cheers house_debug.hiplc Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted January 18, 2020 Share Posted January 18, 2020 (edited) Add an integer parameter at Object level in your geometry, then use an expression that points to the quantity you want to display Example npoints("pack1/") pack1 being the name of a node in your geometry network In your network, you can use connectivity (primitives) and attribute promote (primitive -> detail (max) ) to compute the number of objects for example you can refer to said quantity with detail("attribpromote1/","class",0)+1 Click on the label once at object level to have the text box display the value instead of the formula. Edited January 18, 2020 by AntoineSfx Quote Link to comment Share on other sites More sharing options...
PastaPesto Posted January 18, 2020 Author Share Posted January 18, 2020 Hey AntoineSfx It works! Nice. Thank you very much! Have a nice weekend /PP Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 18, 2020 Share Posted January 18, 2020 (edited) it's nothing but a label....easy peasy vu_Count_Label.hiplc Edited January 18, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
PastaPesto Posted January 18, 2020 Author Share Posted January 18, 2020 Hi Noobini thanks for the tip I ended up using label aswell. Quote Link to comment Share on other sites More sharing options...
